Can you have a shop truck if you don’t have a shop yet? I mean, that’s why I bought it, but at the moment I don’t even have a shed…just a large and rapidly disintegrating asphalt pad on a hill. (If you’ve known me for a while you know it’s luxury, I’m used to turning wrenches in the dirt.)
No, he ain’t gonna die…
TLDR QuickStats:
- 1987 Ford F250 XL Centurion
- 460ci/7.5L V8 / 4-speed AOD transmission
- Sterling 10.25 axle, 4.10 gearing, limited slip, and rear ABS (2WD)
- F350 Suspension
- Extended Cab / Long Bed (finally, 4x8 ply can be carried flat and uncut)
- Gooseneck & Standard Hitches
TLDR QuickPlan/WorkLog:
- Find a tailgate…done
- Rebuild the wiring harness (and remove Centurion nonsense)…95% complete
- Finish removing the ineffective 80’s smog gear, replacing with modern equivalents where appropriate…80% complete
- Replace coolant reservoir and fix coolant leak…done, twice
- Reconnect the aircon and see if it works…in progress, troubleshoot clutch
- Fix d/s headlight retainer…done
- Replace dry-rot tires…done
- Replace door skins, or maybe just the entire doors
- Replace craptastic aftermarket mirrors with Ford Genuine…50% complete
- Fix the parking brake
- Replace trailer brake controller (missing)
- Replace bumpers and rear hitch…
- …add frame reinforcement to known OBS-chassis weak points
- Stereo and speakers…done
- Replace passenger window regulator…done
- Remove window tint
- Replace rear slider with solid window
- Replace front buckets with a bench…done
- Repair rear bench
- Interior restoration…30% complete
- Rework exhaust, hanging way too low…?
- Lower ~4", add helper airbags for occasional heavy loads/towing
- Upgrades: onboard air (for tools), work area lighting, cargo management (done), etc…
- Add ramps with storage, add tie-downs for a pair of motorcycles
Slowly restore the chassis, paint, and chrome to showroom shiny conditionRATROOOOOOOD…
Longform…
@Brian can attest to the fact that I’ve been restoring my beloved Land Rover Discovery for an absurdly long time. It’s not an overly difficult or time consuming job, but it seems every time I start to get something pulled apart to work on it I have to drop what I’m doing and use the faithful beast for some menial task like rescuing Foresters, commuting to an assignment, or hauling hardware (in way too big a trailer). After the dozenth or so time quickly slapping tires/doors/batteries/panels on it I decided it was time to troll Craigslist for a dedicated support vehicle.
Clearly Fate agreed, because a prime specimen of 1980’s workin’ man nostalgia was right at the top of page one. You know those ads that end with “Price goes up next week after I’ve replaced the doohickey.”? This was one of those. I got to him after he’d replaced the carb and gotten that 460 purring like a kitten, but before he completely removed the smog equipment and Centurion “upgrades” (more on those later). He also already replaced the alternator and battery.
No sign of the too-common trapezoid beds and mismatched body lines from tired, overworked frames. A dirty, but completely intact original dash. The idle was quieter and smoother than my modern fuel-injected British V8. It even had a gooseneck and weight distribution setup installed (likely why the frame is still straight). Sure the carpet is toast and the bumpers are twisted, but those are easy fixes. Surely some other piece of truck-sized footwear was about to fall from the sky?
Remember these “hands free” gems? Old school at it’s finest…
