The Day After: I AM THE FEZZIK FACTOR NOW.
I can see it so clearly. @CrankshaftCulture The Universe was talking. I wasn’t listening.
First, I set out my new Adventure Driven Design idler with the CrMo kingpin and bronze bushings. (Mechanical engineer approved!) After bead blasting the case at the shop, it was ready for a couple coats of Rustoleum. Josh was nice enough to include a spare idler arm and the OE kingpin, should I run into any trouble. Of course, then I damaged the tired old bushing on the tired old pitman arm while separating it from the steering, uh, bar. Didn’t have another one of those lying around, so I had to order one.
In the meantime, I set about cleaning and spraying everything with a couple fresh coats of paint to cover up the rust left over from the old lead acid battery days. I set aside the old idler assembly and tie rods, and set out to do the easy job of pulling the rear wheel bearing seals. Sharper eyes will notice there are wheel bearing pictures in the next grouping. No, instead, I tried prying out the MB160850 knuckle oil seal.
I feel like I might have damaged the mating surface, but it might also be I simply removed the rubber from the seal, leaving the shell behind once again. @PajEvo any thoughts here? I had to remove one of them anyway. It was crumbling apart, but now I’m not sure if I should be getting in there with a pry bar and popping those shells out or those are part of the knuckle. Jeez.
Knowing I wouldn’t be installing my LCAs today after all, I decided to see what I could get ready to install when the parts come in this week. I’ve got calipers, lines, rotors, and pads. I figured I could at least get the hubs cleaned up, add new bearings and seals, and mount the slick new rotors.
I may have had a drink at this point. Got the races cleaned out. (Have since noticed RTV remnants inside the race and need to clean it out anyway, but that’s another day’s work.) And then I noticed I had the wrong seals for the wheel hubs, too! Those new Timken bearings look real nice, though. It’s nice handling something mint and precise amidst all the greasy tomfoolery.
Finally, with the last of the satin black Rustoleum I used to paint the bed of my RC truck a month or so earlier, I hit the wheel wells to cover up any exposed metal. I’ll be showering everything in WD-40 a few times between now and next summer, but things are looking fresh now.
Also on order: three sheets of 12in x 24in x 1/16in HPDE so I can make skirts to keep shit out of the engine bay. I masked nothing off, but it looks great from six feet away and the rust is covered. What else do I need?
I love this picture.
Finished strong with another pineapple cider.
- pitman arm and plastic sheets arrive 11/29
- (2) Musashi MB526395 oil seal, fr hub arrive 12/01
- (2) OE MB160850 oil seal, knuckle arrive 12/06-12/08
I’m gonna see if I can get those knuckle seals sooner locally. (Not holding my breath, though.)
